Transformation Sequence Editor Dependencies Order Item Context Subtab
This subtab is visible when you have a transformation stage selected in the tree area. Use the Order Item Context subtab of the Dependencies tab to configure details of the transformation stage.
Field | Use |
Reuse Previous Stage Context |
Select this option to indicate that the current transformation stage should not recalculate the order item context but should use the order item context of the previous stage. Note: This option should not be selected for the first transformation stage in the transformation sequence. |
Order Item Context |
Do one of the following:
Related Topics
