Transformation Sequence Editor Dependencies Tab Stage Detail Subtab
Use the Stage Detail subtab of the Dependencies tab to configure details of the transformation stage. This subtab is visible when you have a transformation stage selected in the tree area.
Field | Use |
Name |
Enter the name of the transformation stage. |
Allow Overrides |
Select this option to set a value that indicates that the results of previous transformation stages may be overridden. Note: This option should not be selected for the first transformation stage in the transformation sequence. |
Related Topics
