Transformation Sequence Editor Dependencies Tab Transformation Model Subtab
Use the Transformation Sequence subtab of the Dependencies tab to define the name of the transformation sequence and to determine whether the stages run in parallel or sequentially. This subtab is visible when you have a transformation sequence selected in the tree area.
Field | Use |
Name |
Enter the name of the transformation sequence. |
Sequential Execution |
Select this option to allow custom sequencing of the transformation stages. See "Configuring Non-Sequential Stage Transitions" for more information about using this option. |
Related Topics
