Combining Order Item Hierarchy with Duration-Based Groupings
You can combine the function to create custom Component IDs based on order item requested delivery date, duration, and minimum duration separation, or a combination of these functions with order component ID generation based on order item hierarchy. The following example creates separate component IDs for order items that, although they have the same requested delivery date, are part of different order item hierarchical groupings:
declare namespace osm="http://xmlns.oracle.com/communications/ordermanagement/model"; declare namespace prop="http://oracle.communications.ordermanagement.unsupported.centralom"; declare namespace osmfn = "java:oracle.communications.ordermanagement.orchestration.generation.OrchestrationXQueryFunctions"; let $groupDuration := "P2D" let $minSeparationDuration := "P1D" return osmfn: getGroupIdByDateTime ($groupDuration, $minSeparationDuration) let $rootAncestorID := osmfn:ancestors("eboLineItem", "default", "http://xmlns.oracle.com/communications/ordermanagement")[fn:last()]/osm:properties/prop:BaseLineId/text() return fn:concat($rootAncestorId, '/', $groupId)
The following table shows how five hierarchically divided order items would be grouped given a one day minimum separation duration.
Order Item | Requested Delivery Date | Group ID | Component ID |
A.1 |
June 9, 2014 |
Group1 |
A/Group1 |
A.1.1 |
June 11, 2014 |
Group1 |
A/Group1 |
A1.2 |
June 19, 2014 |
Group2 |
A/Group2 |
A.1.3 |
June 20, 2014 |
Group2 |
A/Group2 |
B.1 |
June 9, 2014 |
Group1 |
B/Group1 |
B.1.1 |
June 11, 2014 |
Group1 |
B/Group1 |
B.1.2 |
June 12, 2014 |
Group1 |
B/Group2 |
See "About Component Specification Custom Component ID XQuery Expressions" for more information about the context, prolog, and body of this XQuery. See "OSM XQuery Functions" for more information about the OrchestrationXQueryFunctions class.
