Custom Component IDs by Duration and Minimum Separation Duration
You can specify a minimum duration separation value for order items that fall very close to a custom Order ID grouping based on order item requested delivery date and duration. For example, the following XQuery adds a minimum separation value of one day:
declare namespace osm="http://xmlns.oracle.com/communications/ordermanagement/model"; declare namespace prop="http://oracle.communications.ordermanagement.unsupported.centralom"; declare namespace osmfn = "java:oracle.communications.ordermanagement.orchestration.generation.OrchestrationXQueryFunctions"; let $groupDuration := "P2D" let $minSeparationDuration := "P1D" return osmfn: getGroupIdByDateTime ($groupDuration, $minSeparationDuration)
All order item requested delivery dates that fall within one day of a two day grouping, would be included in the two day grouping.
The following table shows how the five order items would be grouped given a one day minimum separation duration.
Order Item | Requested Delivery Date | Group ID |
A |
June 9, 2014 |
Group1 |
B |
June 10, 2014 |
Group1 |
C |
June 11, 2014 |
Group1 |
D |
June 12, 2014 |
Group2 |
E |
June 12, 2014 |
Group2 |
See "About Component Specification Custom Component ID XQuery Expressions" for more information about the context, prolog, and body of this XQuery. See "OSM XQuery Functions" for more information about the OrchestrationXQueryFunctions class.
