About Order Data Change Wait Condition XQuery Expressions
This topic describes how to use the Orchestration Fulfillment Pattern editor, Orchestration Plan tab, Dependencies subtab, Wait Condition subtab, Wait for Condition area, XQuery subtab for the Data Change Notification selection,
This topic describes how to use one of the following fields:
Orchestration Dependency editor, Wait for Condition tab, Wait for Condition area, XQuery subtab for the Data Change Notification selection
to write an expression that specifies a value that must exist in order item property (typically a blocking order item property) before a waiting order item starts.
Context: The Data Change Notification XQuery input document is the task view task data that was changed using an update order transaction.
Prolog: You can declare the $blockingIndexes variable in the XQuery prolog that contains an index of data element for all blocking order items. For example:
declare variable $blockingIndexes as xs:integer* external;
Body: The XQuery body returns a specific value and will wait until all blocking order items have the corresponding value and the XQuery returns true.
The following example shows the XQuery that evaluates the data change. The dependency is met when all blocking order items have reached a state of PROVISION STARTED.
(: The $blockingIndexes variable contains data element indexes for all blocking order items: :) declare variable $blockingIndexes as xs:integer* external; (: Specify "PROVISION STARTED" as the data value that must be met: :) let $expectedMilestoneCode := "PROVISION STARTED" (: $milestoneValues contains a set of milestones for all blocking order items: :) let $milestoneValues := /GetOrder.Response/_root/ControlData/Functions/ProvisioningFunction/orderItem/orderItemRef[ fn:index-of($blockingIndexes, xs:integer(@referencedIndex)) != 0]/milestone[text() eq $expectedMilestoneCode] (: Return true only if all the milestones in ProvisioningFunction/orderItem/orderItemRef are PROVISION STARTED: :) return fn:count($milestoneValues) eq fn:count($blockingIndexes)
The following example returns true when at least one blocking item is completed.
declare namespace oms="urn:com:metasolv:oms:xmlapi:1";
let $component := //ControlData/Functions/NetworkProvisionFunction
let $lineItem := $component/orderItem/orderItemRef[fn:index-of($blockingIndexes, xs:integer(@referencedIndex)) != 0]
return
if (fn:exists($lineItem))
then
let $statusValue := $lineItem/OrderItemStatus/text() = "completed"
return
if (fn:count($statusValue)>0)
then
fn:true()
else
fn:false()
else
fn:false()
