Mapping Rule Editor Mapping Tab Actions Subtab
Use the Actions subtab to set action mappings for the selected named relationship. These mappings override any mappings that are set on the relationship itself.
Field | Use |
Action Codes |
Enter the action codes that apply to this mapping. Do any of the following:
Use Relationship Action Map |
Select this option to inherit action mapping information from the named relationship. This is selected by default. |
Action Mapping Type |
Deselect Use Relationship Action Map to access these options. Do one of the following:
Action Maps area |
This area appears when you select the Simple action mapping type. The table in this area displays the action maps defined for this mapping rule. Do any of the following:
Output Action Code area |
This area appears when you select the Simple action mapping type. Select the desired action code to set the transformed order item. |
Input Action Code area |
This area appears when you select the Simple action mapping type. Select the action code for the original order item. |
Current Action Code area |
(Optional) This area appears when you select the Simple action mapping type. Use this field to produce a different output action code depending on the current action code of the transformed order item. |
Related Topics
