Mapping Rule Editor Mapping Tab Fulfillment State Filters Subtab
Use the Fulfillment State Filters subtab to configure which external fulfillment states will be propagated for order items associated with the selected named relationship.
Field | Use |
Fulfillment State Filters area |
The table in this area contains the order component specifications whose external fulfillment states should be propagated. Fulfillment states for any order component that is not in this table will not be propagated. Do any of the following:
Fulfillment State Filter area |
This area enables you to select specific external fulfillment states to propagate. External fulfillment states that are not included in this area will not be propagated. Select an order component in the Fulfillment State Filters area and do any of the following:
Related Topics
