Mapping Rule Editor Mapping Tab Details Subtab
Use the Details subtab to configure details about the selected named relationship.
| Field | Use |
Use for Order Item Selection |
Select this option to use this relationship to select the order items for the transformation. |
Supports Bi-directional Mapping |
Select this option to propagate data that is changed on the transformed order item during order execution back to the original order item. |
Named Relationship |
This field contains the name of the relationship between the input and output entities. See "Product Editor Derivation Tab" for more information about creating this relationship in a conceptual model product. See "Conceptual Model Editor Components Tab" for information about creating this relationship for other types of conceptual model entities. |
Input Conceptual Model Entity |
Displays the name of the conceptual model entity that is related to the original order item. |
Input Action |
Select an action to use for the input entity. This action provides additional data elements for the source of the mapping. |
Output Conceptual Model Entity |
Displays the name of the conceptual model entity associated with the transformed order item. |
Output Action |
Select an action to use for the output entity. This action provides additional data elements for the target of the mapping. |
Related Topics
