Mapping Rule Editor Mapping Tab Mapping Subtab
Use the Mapping subtab to map entities and data elements to the appropriate values on the transformed order item.
Field | Use |
Input |
This tree contains the properties of the original order item and the parameters on the source entity. |
Output |
This tree contains the properties of the transformed order item and the parameters on the target entity. |
Mapping Rule Item area |
This area contains the specifics for the individual mappings. For more information about the contents of this section for the different mapping types, see "Configuring Mappings". |
Related Topics
