Order Item Fulfillment State Condition Details Subtab
Use the Condition Details subtab to specify the criteria that must be met for the selected condition to be evaluated. If no condition is selected, these fields are disabled.
Field | Use |
Description |
Edit the display name of the condition. If you are localizing OSM, use the list to the right of the field to set different values for different locales. |
Type |
Select Any when the condition requires at least one of the input order item's fulfillment states to match one of the selected fulfillment states. Select All when the condition requires all of the input order item's fulfillment states to match one of the selected fulfillment states. Select None when the condition requires that none of the input order item's fulfillment states match any of the selected fulfillment states. |
Fulfillment State tree |
Select one or more fulfillment states for matching to the rule's input fulfillment states. If a parent fulfillment state is selected, it includes the child fulfillment states also. |
Property Values |
Select one or more order item properties, and then enter a value for each. For the condition to be met, the order item must contain the specified property and that property must have the specified value. If both property values and fulfillment states are defined on the same condition, both the property value and fulfillment state conditions must be met. Do any of the following:
Related Topics
