Order Item Fulfillment State Rule Details Subtab
Use the Rule Details subtab to specify the composite fulfillment state to be assigned to the associated order item when the selected rule's conditions are met. If no rule is selected, these fields are disabled.
Field | Use |
Description |
Edit the display name of the composition rule. If you are localizing OSM, use the drop-down list to the right of the field to set different values for different locales. |
Composite State |
Select the fulfillment state to be assigned to the composition rule's order item when all of the rule's composition conditions are met. |
See the following for more information about configuring rules and conditions on the Rule Details subtab:
Related Topics
