Order Fulfillment State Condition Details Subtab
Use the Condition Details subtab to specify the criteria that must be met for the selected condition to be evaluated. If no condition is selected, these fields are disabled.
| Field | Use |
Description |
Edit the display name of the condition. If you are localizing OSM, use the list to the right of the field to set different values for different locales. |
Type |
Select Any when the condition requires at least one of the input order's fulfillment states to match one of the selected fulfillment states. Select All when the condition requires all of the input order's fulfillment states to match one of the selected fulfillment states. Select None when the condition requires that none of the input order's fulfillment states match any of the selected fulfillment states. |
Fulfillment State tree |
Select one or more fulfillment states for matching to the rule's input fulfillment states. If a parent fulfillment state is selected, it includes the child fulfillment states also. |
Key Expression |
Enter an XQuery expression that must evaluate to true (per the XPath Boolean definition) in order for the condition to be satisfied. |
Related Topics
