Importing Product Specifications
The product specification import process now produces conceptual model products rather than OSM product specifications. For information on importing conceptual model products, see "Importing Products".
If, in the Order Item Specification editor, you have configured an XQuery expression to reference a data instance for the fulfillment pattern property, ensure that you update the external file with the product-specification-to-fulfillment-pattern mapping information and redeploy the file to the proper URI.
If you have configured an XQuery expression to run against the order item property, you must update the XQuery expression for the order item property that you have identified as the fulfillment pattern, save the order item specification, and redeploy the cartridge before submitting orders that request any new products. See "Order Item Specification Editor Order Item Properties Tab" for more information.
