Transformed Order Item Fulfillment State Source Order Item Subtab
Use the Source Order Item subtab to filter the conditions to be evaluated based on the conceptual model entity associated with the source order item.
Field | Use |
Simple |
Select this option to filter the composition rules based on the conceptual model entities configured in the Conceptual Model Entity field. |
Advanced |
Select this option to use the expression in the XQuery field to filter the composition rules. |
Conceptual Model Entity |
This field enables you to define the conceptual model entities that must be associated with the order item for the condition to be evaluated. This field is only available if you have selected the Simple option. |
XQuery |
This field enables you to determine the relevant conceptual model entities using an XQuery expression. This field is only available if you have selected the Advanced option. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Transformed Order Item Fulfillment State XQuery Expressions" for more information about this particular XQuery field. |
