Order Item Specification Editor Order Item Dependencies Tab
Use the Order Item Dependencies tab to configure order item dependencies between order items on different orders.
See "Working with Orchestration Dependencies" for more information about configuring order item dependencies that are not based on orchestration fulfillment patterns.
See "Order Item Specification Editor" for information about fields that appear on multiple Order Item Specification editor tabs.
Field | Use |
Order Item Dependencies |
Associate the order item with one or multiple dependencies with order items on different orders. Click:
Order Item Selector Expression |
Specify an XQuery expression to select the order item on which the corresponding order item depends. See "Order Item Specification Editor" and "About Order Item Inter-Order Dependency XQuery Expressions" for more information. |
