Order Item Specification Editor Order Item Hierarchies Tab
Use the Order Item Hierarchies tab to define the relative hierarchies among order items.
An order item hierarchy represents a logical parenting of order items in the order. Incoming customer orders may contain multiple order item hierarchies. For example, a single order item may exist in multiple hierarchies.
See "Order Item Specification Editor" for information about fields that appear on multiple Order Item Specification editor tabs.
Field | Use |
Physical Hierarchy |
Select the hierarchy for OSM to use for the order items on the order, or delete the selection to process the order item without a hierarchy. |
Composition Hierarchy |
Select the hierarchy for OSM to use in determining fulfillment states, or delete the selection for OSM to use only the order item's order components to determine the order item fulfillment state. |
Dependency Hierarchy |
Select the hierarchy for OSM to use in determining dependencies between order items, or delete the selection for OSM to use only the order item's order components to determine the order item dependencies. You cannot select Use for Child Completion Dependency with the Dependency Order Item Hierarchy. Design Studio generates an error message if you do. |
Order Item Hierarchies list |
Associate the order item with one or multiple hierarchies. Click:
Key Expression |
Specify an XQuery expression to select the key value for the corresponding order item within a specific hierarchy (for example, within a line number). See "Order Item Specification Editor" and "About Order Item Specification Order Item Hierarchy XQuery Expressions" for more information. |
Parent Key Expression |
Specify an XQuery expression to select the parent key value for the corresponding order item within a specific hierarchy (for example, within a parent line number). See "Order Item Specification Editor" and "About Order Item Specification Order Item Hierarchy XQuery Expressions" for more information. |
