About Calculate Behaviors
The Calculate behavior enables you to calculate a field's value based on a formula that references other field values. When defining Calculate behaviors on the Calculation Behaviors Properties tabs, you can use XPath expressions to support numeric operations and string concatenations. For example:
| XPath Expression | Result |
Set the current field equal to the value found in the ../loopback field |
Set the current field equal to a concatenation between the letter S and the value found in the Port field that is returned by the peinterefacedetails data provider. |
Set the current field equal to the portType returned by the interfacedetail data instance provider. |
See OSM Concepts for more information about behavior default values, inheritance, and declarative syntax. For more information about XPath specifications, see the World Wide Web Consortium (W3C) website at:
XPath uses path expressions to select data nodes in XML documents. A path expression with a single dot (.) represents the current node. Two dots (..) represents the parent of the current node. A slash (/) represents the root node.
XPath and XQuery fields are limited to 4000 characters.
