About Submit Test
The Design Studio Submit Test feature enables you to submit a sample XML order to a run-time environment for the purpose of testing your cartridge model. For example, if you were creating recognition rules for an orchestration cartridge, you could submit sample orders to ensure that the OSM server was properly recognizing the input messages for each recognition rule and directing the order to the right cartridge. Additionally, you could target the sample order to a specific version of a cartridge, test OSM behaviors, and so forth.
When submitting sample orders to run-time environments, the root level of the sample order XML document must be either the CreateOrder or the CreateOrderBySpec XML API request. For example:
<?xml version="1.0" encoding="UTF-16"?>
<ord:CreateOrder xmlns:ord="http://xmlns.oracle.com/communications/ordermanagement">
<zeb:order xmlns:zeb="http://www.example.org/zebra" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
     <zeb:sampleLine>
          <zeb:lineName>newPhoneLine</zeb:lineName>
          <zeb:class>potsService</zeb:class>
     </zeb:sampleLine>
</zeb:order>
</ord:CreateOrder>
You save all sample XML orders in a project samples directory, accessible from the Package Explorer view.
