Submitting Test Orders to Run-time Environments
The Design Studio Submit Test feature enables you to submit a sample XML order to a run-time environment for the purpose of testing your cartridge model.
To submit test orders to run-time environments:
  1. From the Package Explorer view, copy a sample XML order into the project samples directory.
  2. Connect to an environment.
    See "Testing Run-Time Environment Connectivity" for more information.
    When connecting to the environment, ensure that the account that you use to log-in is set up properly in WebLogic. To submit tests from Design Studio, user accounts must be assigned to the OMS_client and OMS_ws_api groups in WebLogic.
  3. If necessary, deploy the full cartridge to the run-time environment.
    See "Deploying Cartridge Projects" for more information.
  4. From the Studio menu, select Show Design Perspective.
  5. In the Studio Projects view, right-click a cartridge and select Submit Test.
    If you have successfully connected to an environment, and your project contains a valid sample order in the project samples directory, Design Studio displays a list of environments and files available to submit.
  6. Select an environment and order combination.
    The Console view is displayed, indicating the status of the submitted order. If the connection is successful, the Console view displays the OSM server response, which includes the order ID, version number, the cartridge name, and so forth. Design Studio opens a browser window in the editor area that points to the log-in window for the environment.
    For the browser window in the editor area of Design Studio to work with OSM, you must configure Eclipse to use a supported external browser. See "Defining Web Browser Preferences" for more information.
    Starting with OSM 7.2, order IDs are allocated in blocks. For OSM running on a standalone database, there is no visible impact. However, if OSM is running on an Oracle RAC database, Order IDs are assigned from different blocks, one for each Oracle RAC instance. This means that when orders are submitted, the Order IDs may not be sequential.
  7. Log into the environment.
    The web client displays a list of orders submitted to the environment.
  8. Locate the table row that contains your sample order.
    For example, you might locate the row using the order ID displayed in the Console view.
  9. Double-click the sample order to open the order and review the order data in the web client tabs.
    For example, if you were submitting a sample order for an orchestration cartridge, you could review the information in the Summary tab, Data tab, Orchestration Plan tab, and so forth.
    For information about the fields in the Order Management web client, see OSM Order Management Web Client User's Guide. For information about the fields in the Task web client, see OSM Task Web Client User's Guide.
  10. (Optional) Update the cartridge with additional changes, save the changes, and use the optimize deploy feature to deploy only the cartridge metadata changes.
    See "Deploying Cartridge Projects with Optimize Deploy" for more information.
  11. (Optional) Connect to another environment to test the cartridge model in multiple environments.
    For each environment that you submit tests to, Design Studio opens a separate browser window. See "Testing Run-Time Environment Connectivity" for more information.
  12. (Optional) Clear the environment connection information if you want to submit a sample order as a different user.
    From the Studio Projects view, right-click a cartridge and select Submit Test, then select an environment, then select Clear Environment Credentials to clear the environment connection information.
