Defining Web Browser Preferences
When you submit test orders from Design Studio to a run-time environment, Design Studio opens a browser window in the Design Studio editor area and displays the Task web client log-in window. For the Task web client to work correctly from inside Design Studio, you must configure Design Studio to use a supported external browser.
To specify an external browser:
                     From the Window menu, select Preferences. The Preferences dialog box is displayed.
                     In the Preferences navigation tree, select Web Browser.
                     In the Web Browser area, select Use external web browser.
                     In External web browser:, select a supported external browser, such as Internet Explorer.
                     Click OK. Design Studio saves your preferences.
Related Topics
