Properties View Custom Plug-in Tab
Use the Properties view Custom Plug-in tab to define a custom automation plug-in entity in Design Studio. The Custom Automation Plug-in editor associates a Java class representing the custom automation plug-in to the custom automation plug-in entity.
This tab appears when the selected plug-in is a custom automation plug-in. The value is initialized with the value of the XML template for the type of custom automation plug-in.
See OSM Developer's Guide for more information about defining the custom automation plug-in.
