Task Editor
Use the Task editor to model the tasks you use in your processes to offer a specific service to a customer. Each task type has its own set of tabs in the Task editor. The following table lists the Task editor tabs that appear for each task type.
Tab Name | Manual Task | Automated Task | Activation Task | Transformation Task |
No |
No |
Yes |
No |
No |
Yes |
No |
Yes |
Yes |
Yes |
No |
No |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
Yes |
No |
No |
No |
Yes |
No |
No |
No |
Yes |
No |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
No |
No |
Yes |
No |
The following field is common to multiple tabs in the Task editor:
Field | Use |
Description |
Edit the display name of the task. |
