Working with Transformation Tasks
Transformation tasks enable you to access a transformation manager from an OSM process. These tasks are similar to automated tasks, except that the automation plug-in is prepopulated when the task is created. However, you are not restricted to using the provided automation plug-in. All of the plug-in configuration options that are available with automated tasks are also available with transformation tasks.
Model your order transformation manager entities before you model the transformation task. For more information about modeling order transformation, see OSM Concepts.
