Task Editor Behaviors Tab
The Task editor Behaviors tab appears for manual and automated task types.
Use the Behaviors tab to view all of the behaviors defined for the data nodes in a manual task and an automated task.
The Behaviors table displays the name and type of the task, whether the behavior is enabled, the inheritance properties, the path name of the data node on which the behavior is defined, and the task where the behavior was originally defined.
The information on the Behaviors tab is read-only. To change the information that appears on this tab, select a behavior from the table and click the Properties button to access the Behaviors Properties tabs. See "Working with Behaviors" for more information about the defining behavior properties.
