Task Editor Fallouts Tab
The Task editor Fallouts tab appears for manual, automated, and transformation task types.
Use the Fallouts tab to specify the types of fallout that can occur for a task.
Click Add to open the Select Fallouts dialog box, where you can select fallouts previously defined on the Order editor Fallouts tab.
Select any fallout defined in the Name column and click Remove to delete the fallout from the list.
Select any fallout defined in the Name column and click Open to open the fallout in the Order editor Fallouts tab.
Related Topics
About Task Fallout
