Task Editor Undo Tab
The Task editor Undo tab appears for IP Service Activator and ASAP activation tasks. (A new activation task is designated to be either an IP Service Activator or ASAP activation task when you choose the Activation System value on the Activation Task Wizard.)
Use the Undo tab to define part of your compensation strategy for activation tasks: to undo tasks that are affected by amendments. Complete the compensation strategy for activation tasks on the Redo tab. See "Task Editor Redo Tab" for more information.
| Field | Use |
Compensation Strategy (ASAP only) |
Specify the compensation strategy to undo a task when it is affected by an amendment:
Compensation Strategy (IP Service Activator only) |
Cancel original order (IP Service Activator only) |
When Compensation Strategy is set to Undo, this option cancels the original order id. |
Create a new order to undo (IP Service Activator only) |
When Compensation Strategy is set to Undo, you can configure a new task to undo, by specifying the data node that contains the Activation order ID. The Activation order ID is configured on the Activation Task Details tab. See "Task Editor Activation Task Details Tab" for more information. |
