Task Data Node Properties View Dictionary Tab
Use the Task Data Node Properties View Dictionary tab to edit the information defined for the corresponding data element at the task level.
Right-click any attribute in the Task editor Task Data tab and select Open Properties View to edit the data element properties at the task level.
| Field | Use |
Name |
Displays the name of the element as defined in the Data Dictionary. The name of the node is not available for edit. You can edit the value in the Display Name field on the Data Schema editor Details subtab to edit the manner in which the element displays. |
Display Name |
Displays the name of the element as it will appear in the Task web client. You can define different display names for the languages that you support in the Task web client. Only those languages defined on the Windows, Preferences, Oracle Design Studio dialog box appear as options. See "Defining OSM Preferences" for more information about defining languages for use in OSM. |
Type |
Displays the data element type. This field is read-only. |
Max Length |
Maximum number of units of length for a string element type. This field is read-only. |
Minimum or Maximum |
Displays the Minimum and Maximum field values as defined in the Data Dictionary. See "Task Data Node Properties View Identification Tab" for information about overriding this value. |
Path |
Displays an XPath expression to define the location of the node in the Data Dictionary. This field is read-only. |
Namespace |
Identifies the namespace in which this cartridge exists, and identifies cartridge version within the namespace, if applicable. |
