Task Editor Permissions Tab
The Task editor Permissions tab appears for manual, automated, activation, and transformation task types.
Use the Permissions tab to assign roles to each of the three possible task execution modes.
Field Use
Do, Redo, Undo, Do in Fallout, Redo in Fallout, and Undo in Fallout
For each role listed in the Role Name column, select or deselect, as appropriate, the Do, Undo, Redo, Do in Fallout, Redo in Fallout, and Undo in Fallout check boxes to enable or disable access to the task execution modes.
These options represent the three possible task execution modes:
  • Do is the default mode for a task that executes under normal processing.
  • Undo reverses the effects of the associated Do operation.
  • Redo combines both Undo and Do operations in a single operation.
  • Do in Fallout is the mode for a task that executes when the task fails while running in Do mode.
  • Undo in Fallout is the mode for a task that executes when the task fails while running in Undo mode.
  • Redo in Fallout is the mode for a task that executes when the task fails while running in Redo mode.
Select
Click Select to select a predefined role to add to the permissions list. If no roles have been previously defined, click New to create a role.
You must define at least one role in the permissions list for every task.
New
Click New to open the Role wizard and create a new role to assign to the task. To select a role that was previously defined, click Select.
Open
Select any role in the Role Name column and click Open to open the role in the Role editor.
Remove
Select any role in the Role Name column and click Remove to delete the role from the task permissions list.
