Task Editor Response Data Tab
The Task editor Response Data tab appears for activation task types.
Use the Response Data tab to map responses to OSM data structures and configure state and status transitions for completion events and exceptions returned by the activation system.
| Field | Use |
Event/Exception |
Select an event or an exception. For each event or exception, you define:
Events and exceptions that include any mapping or transition configuration are represented by a shaded (green) flag icon. Events and exceptions with no configuration defined are represented by an empty (or gray) flag icon. |
Activation Response |
Select the data returned from the activation system that updates the OSM order. If you do not select a data field for an event or exception, OSM ignores that event or exception. |
Response Data Location |
Define the OSM data structure to contain the data returned from an event or exception. For each event or exception, you select an existing data structure from the order template or from the data dictionary and right-click that data structure to define the data location. See "Configuring Service Action Responses" for more information. |
OSM Data Binding |
Bind activation response elements to arbitrary task data elements by dragging elements from the Activation Response area onto OSM data structures. Note: Do not add an OSM data structure in this field that uses a distributed order template. Attempting to map a response value to a data element in a distributed order template will cause an error. For more information about distributed order templates, see OSM Concepts. |
Transition to State or Status |
Displays default transitions defined for completion events and exceptions. You can define additional state transitions for user-defined states and additional transitions for predefined task statuses using the Add button. |
Move Up and Move Down |
Select a state or status transition row in the Transition to State or Status table and click Move Up and Move Down to change the order in which OSM evaluates the transition conditions at run time. |
Properties |
Select a state or status transition row in the Transition to State or Status table and click Properties to define the condition against which OSM evaluates the transition. See "Properties State/Status Transition View" for more information. |
Response Filter |
Enables you to limit the amount of response data sent to update OSM order data. See "Response Filter Area" and "Filtering ASAP Response Data" for more information. |
Remove |
Select a state or status transition row in the Transition to State or Status table and click Remove to delete the transition. |
Add |
Click Add to define a new user-defined state or status transition for a selected event or exception. |
