Properties State/Status Transition View
Use the Properties State/Status Transition view to define the condition against which OSM evaluates (at run time) a state or status transition for a service action response.
| Field | Use |
Condition Name |
Displays the condition name as defined on the Response Data tab in the Transition to State or Status table. |
State/Status |
Displays a user-defined state or status transition as defined on the Response Data tab in the Transition to State or Status table. Click Select to change the state or status. |
Condition |
Define the condition against which OSM evaluates the transition. At run time, OSM evaluates the conditions in an order you define and stops evaluating when a condition evaluates to true. For example, consider that you want to define a condition for the orderFailEvent to transition the task to a suspended state (NEUnknown) because of a network element error. You can define the condition in the following manner:
Note: The |
