Task Editor Composite Data View Tab
The Task editor Composite Data View tab appears for manual, automated, and transformation task types.
Use the Composite Data View tab to display all of the data that is available to a task within the context of an OSM solution. For example, if you added a new fulfillment function to extend a solution, you would see the additional data nodes required by the function as well as any new control data. The task data in the Composite Data View tab is read-only. You model the data in the Task Data tab of the Composite Cartridge View editor.
Tip:
A The composite data view has at least the same number or more data nodes than its corresponding task view.
| Field | Use |
Solution |
Select the solution to display all of the task data associated with the solution. |
Task Data |
Displays all of the data that is available to a task, including additional data that has been contributed within the context of a solution. You cannot modify any data that appears in the Task Data area. |
Behaviors |
Displays all of the behaviors defined for each data node. Select a data node in the Task Data area to view the behaviors defined for the node. You cannot modify any behaviors that appear in the Behaviors area. |
