Properties View Details Tab
Use the Properties view Detail tab to define information that is common to all types of automation plug-in and event receiver types.
| Field | Use |
Name |
Enter a plug-in name. The name must be unique among plug-in entities in the same namespace. Note: While plug-in names can be any arbitrary name that you assign to the automation, Oracle recommends that you use a consistent naming pattern for all of the automations that you create. |
EJB Name |
Edit the system-provided default EJB name. The default value with which Design Studio initially populates this field depends on where the automation is defined:
Note: The EJB name must be unique per OSM server. However, as there is no method for predicting to which OSM server the cartridge will be deployed, you should ensure uniqueness across all automation plug-ins defined for a cartridge. The default EJB name guarantees this uniqueness; therefore, Oracle recommends that you do not change the defaulted EJB name. See "Working with Jeopardy and Event Notifications" for more information jeopardy and event notifications. |
Run As |
Enter the OSM user name (security principal) whose credentials are used to execute this automation plug-in. A password is not necessary to authenticate this user because only an administrator has the authority to deploy components into the server. The value of this field must reflect the user ID that is used to run the automation:
Note: Oracle recommends using the DEFAULT_AUTOMATION_USER cartridge model variable in the Run As field. See "Defining Model Variables" for more information. |
Event Type |
This field is enabled only for automations defined for automated tasks. Select one of the following:
Note: If you intend to secure automations such that different user IDs have access to run different automations, Oracle recommends that you incorporate these changes after you ensure that the automations are working successfully. Changing a plug-in's automation event type may result in the loss of any data that is not common between the event receiver types. |
Fail Task on Automation Exception |
Select this check-box to fail the task if an exception occurs when running the automation plug-in. The plug-in can throw any exception and OSM retries the plug-in as many times as configured on the JMS destination retry. On the last retry attempt OSM fails the task and logs the exception message as the failure reason. |
