Defining Behavior Detail Properties
Behavior detail properties are common to all behaviors. You can disable behaviors temporarily, override the manner in which behaviors are inherited, determine where a behavior was initially defined, and so forth.
The level at which you create a behavior (at the data element level, task level, or order level) determines where you access and configure the behavior's properties. See "Creating New Behaviors" for more information.
To define behavior property details:
  1. From the Design perspective, right-click the behavior and select Open Properties View.
    The Behaviors Properties view is displayed.
  2. Click the Details tab.
    The Behaviors Properties view Details tab is displayed. The Name, Type, and Path field values are read-only, and cannot be modified on this tab.
