Behaviors Properties View Details Tab
Use the Behaviors Properties View Details tab to enable behaviors and to force local, specific exceptions to the way behaviors are evaluated for a given node.
The Properties view Details tab is common to all behaviors.
Field Use
Name
Displays the name of the behavior. To rename a behavior, from the Behaviors area right-click the behavior and select Rename.
Note: The name of the behavior can only be changed in the location at which the behavior is defined.
Type
Displays the type of behavior selected.
Path
Displays the node context on which the behavior is defined.
Origin
Displays where the behavior is defined. The behavior's inheritance properties are determined by the definition location.
Enabled
Deselect to disable the behavior in the run-time environment. If you disable a behavior and deploy the cartridge, the OSM server will ignore this behavior. For example, you can disable behaviors during testing. By default, this check box is selected.
Final
Select to prevent another behavior of the same type, for the same node, at the same or more specific level from overriding that behavior.
Override
Select to indicate that the behavior takes precedence over any other behavior of the same type, for the same node, at the same or more general (order) level.
Note: Override does not function if the behavior that you are trying to override has the Final attribute enabled.
