Defining Behavior Condition Properties
You can apply conditions to a behavior that determine if it is applied, based on the view data.
The level at which you create a behavior (at the data element level, task level, or order level) determines where you access and configure the behavior's properties. See "Creating New Behaviors" for more information.
To define behavior conditions:
  1. From the Design perspective, right-click a behavior and select Open Properties View.
    The Behaviors Properties view is displayed.
  2. Click the Conditions tab.
    The Behaviors Properties view Conditions tab is displayed.
  3. Click Add.
    A new condition is displayed in the Condition field with the default name Condition. The default XPath expression true() appears in the XPath Expression field.
  4. Select the default condition name to change the default name.
  5. Select the default XPath expression to replace it or modify it.
  6. Click Remove to delete a selected condition.
