About Behavior Condition Properties
You can apply conditions to any behavior to determine the conditions under which the behavior should apply. You can add conditions as XPath expressions against which the behavior can run a Boolean compare. If the Boolean compare returns true, the behavior is applied.
For example, to associate a behavior with a postal code field in a web client to target all customers in a specific region, you might apply the condition:
../postal_code = '95419'
You can select a data node from the Order Template tab (when working in the Order editor) or from the Task Data tab (when working in a Task editor) and drag the selected data node into the XPath Expressions field to define the XPath expression. To drag a data node into the Properties view Conditions tab, press and hold the Alt key before you select and drag the data node to the XPath Expressions field.
XPath uses path expressions to select data nodes in XML documents. A path expression with a single dot (.) represents the current node. Two dots (..) represents the parent of the current node. A slash (/) represents the root node.
XPath and XQuery fields are limited to 4000 characters.
When no condition is defined for the behavior, the OSM server will always apply the behavior. When you define multiple conditions for the behavior, all conditions must evaluate to true for the OSM server to apply the behavior.
Defining Constraint Behavior Condition Properties
When defining conditions for Constraint behaviors, you specify the conditions that must be satisfied to avoid triggering the behavior. If any one of the conditions defined for the Constraint behavior are not met (those that evaluate to false), the OSM server triggers the constraint and displays the appropriate message to the user, based on the severity level. If no conditions are specified, the constraint will not be triggered.
See OSM Concepts for more information about behavior default values, inheritance, and declarative syntax.
