Behaviors Properties View Conditions Tab
Use the Behaviors Properties View Conditions tab to apply conditions to a behavior to determine when the behavior should apply.
The Properties view Conditions tab is common to all behaviors.
| Field | Use |
Add |
Click to apply a new condition to the behavior. |
Conditions |
Displays the list of conditions defined for the corresponding behavior. Select a condition to rename it. |
XPath Expression |
Displays the XPath Expression that defines the logic of the corresponding condition. Select the expression to modify or remove it. To drag a data node into the Properties view Conditions tab, press and hold the Alt key before you select and drag the data node to the XPath Expressions field. XPath and XQuery fields are limited to 4000 characters. |
Remove |
Click to remove the highlighted condition. |
