Information Behavior Properties View Help Tab
On the Properties view Help tab, you can create context-sensitive, online help in the web client by selecting a language and defining the help topic and text.
Field Use
Language
You can declare Information behaviors specific to a given language by using the optional Language attribute. If this attribute is set, OSM automatically selects the appropriate instance using the user's language preferences set in the web browser.
Topic
Enter the topic name for this help message.
Message
Enter the help documentation that will be displayed in the web client when the user clicks the associated field Help button.
Note: Use valid HTML to enter the help message.
