Information Behavior Properties View Hints Tab
On the Properties view Hints tab, you can create hints (tool tips) in the web client by selecting a language and defining a message.
| Field | Use |
Language |
You can declare Information behaviors specific to a given language by using the optional Language attribute. If this attribute is set, OSM automatically selects the appropriate instance using the user's language preferences set in the web browser. |
XPath Expression |
Enter a mathematical expression or an XPath Expression. You can select a data node from the Order Template tab (when working in the Order editor), or from the Task Data tab (when working in a Task editor) and drag the selected data node into the XPath Expression field to define the XPath expression. To drag a data node into the Properties view Hint tab, press and hold the Alt key before you select and drag the data node to the XPath Expressions field. XPath uses path expressions to select data nodes in XML documents. A path expression with a single dot (.) represents the current node. Two dots (..) represents the parent of the current node. A slash (/) represents the root node. XPath and XQuery fields are limited to 4000 characters. |
