In Progress Compensation Grace Period XQuery Expressions
You can determine whether a grace period should be observed before starting compensation for an in progress task by writing an XQuery expression in the Design Studio Task Editor Compensation tab.
If the XQuery expression is invalid OSM logs the error and includes the in progress task in the compensation plan as it defaults the expression to true.
This section refers to the Design Studio OSM Automated Task or Manual Task editor, Compensation tab, When an amendment occurs if this task is in progress it will: tab, Dynamic Expression XQuery field for dynamically defining the grace period for an in progress task based on task data. This XQuery expression runs after OSM has determined whether the in progress task needs to be compensated:
Context: The context for this XQuery is the current task order data. You can get the current task order data using the XML API GetOrder.Response function.
Prolog: You can declare the XML API namespace to use the GetOrder.Response function in the XQuery body to extract the order information. You can also declare the $gracePeriod variable in the XQuery prolog which contains the grace period specified on the order life-cycle policy.
For example:
declare namespace osm = "urn:com:metasolv:oms:xmlapi:1"; declare namespace log = "java:org.apache.commons.logging.Log"; declare variable $gracePeriod external; declare variable $log external; declare variable $context external;
Body: The XQuery body returns a duration value based on the XQuery you enter:
PyYmMdDThHmMsS
where
P begins the expression.
yY specifies the year.
mM specifies the month.
dD specifies the day.
T separates the parts of the expression indicating the date from the parts of the expression indicating the time.
hH specifies the hour.
mM specifies the minutes.
sS specifies the seconds.
For example, this XQuery uses order data to define the specific grace period duration for the task. The last statement calls the $gracePeriod variable which represents the grace period duration specified on the order life-cycle policy:
let $inputDoc := self::node()
let $value := $inputDoc/GetOrder.Response/_root/data
return (
if (fn:contains($value, '-immediate-')) then
xs:duration('PT0S')
else if (fn:contains($value, '-override-')) then
xs:duration('PT20S')
else if (fn:contains($value, '-negative-')) then
xs:duration('-PT10S')
else if (fn:contains($value, '-invalidNumber-')) then
fn:number(0)
else if (fn:contains($value, '-invalidString-')) then
xs:string('UNKNOWN')
else
xs:duration(fn:concat('PT', $gracePeriod, 'S'))
