Order Jeopardy Editor Automation Tab
Use the Order Jeopardy editor Automation tab to configure an automation that is triggered by the jeopardy. The following table describes the fields on the Order Jeopardy editor Automation tab.
See "Order Jeopardy Editor" for information about fields that appear on all of the Order Jeopardy editor tabs.
When configuring order jeopardy automations, see also the following topics:
| Field | Use |
Trigger Automation when Jeopardy is Raised |
Select this option to cause an automation plug-in to be called when the order jeopardy is raised. |
Automation Type |
Select the automation plug-in type from the available list. See "Working with Automation Plug-Ins" for more information about the different automation types. |
Custom Automation Plugin |
If you selected Custom Automation in the Automation Type field, enter the name of the custom plug-in. |
