Order Jeopardy Editor Policy Tab Data Path Expression Subtab
Use the Order Jeopardy editor Policy tab, Data Path Expression subtab to set the details of the duration jeopardy timer. This subtab is available if the Specify a Data Path Expression to evaluate the duration option is selected in the Order Jeopardy editor Policy tab, Timer Duration area.
| Field | Use |
Data Path |
Select the data node that contains the duration. Do any of the following:
Related Topics
