Order Jeopardy Editor Policy Tab Unit Type and Default Value Subtab
Use the Order Jeopardy editor Policy tab, Unit Type and Default Value subtab to set the unit type of the duration and a default value if the value is not found. This subtab is available if the Specify an Xquery Expression to evaluate the duration option or the Specify a Data Path Expression to evaluate the duration option is selected in the Order Jeopardy editor Policy tab, Timer Duration area.
| Field | Use |
Expression Units |
Select the units of measure used in the returned duration value. |
Default |
Enter the default value to be used if the XQuery expression or data path do not return a valid value. The value in this field is expressed in the units selected in the Expression Units field. |
Related Topics
