Order Jeopardy Editor Policy Tab
Use the Order Jeopardy editor Policy tab to define the order states and duration for the timer. The following table describes the fields on the Order Jeopardy editor Policy tab.
See "Order Jeopardy Editor" for information about fields that appear on all of the Order Jeopardy editor tabs.
When configuring order jeopardy policy timer duration, see also the following topics:
Order Jeopardy Editor Policy Tab Unit Type and Default Value Subtab
Order Jeopardy Editor Policy Tab Data Path Expression Subtab
| Field | Use |
Start Condition |
Specify the order states that, when the order enters one of them, should start the jeopardy timer. This should be set if the value being returned in the Timer Duration area is a duration, rather than a date/time. If this value is not set, OSM will expect a date/time value to be returned from the configuration in the Timer Duration area. Since the Specify a Duration Value and Use the Order Expected Duration options always return a duration, this value should always be set if either of those options is selected. Do any of the following:
Pause Timer and Block Jeopardy |
Specify the order states that, when the order enters one of them, should pause the jeopardy timer. This should not be set if Start Condition does not have a value. If Start Condition has a value, this field is optional. Do any of the following:
Stop Condition |
Specify the order states that, when the order enters one of them, should stop the jeopardy timer. This value should always be set. Do any of the following:
Timer Duration |
Sets the time after which a jeopardy will be raised. Do one of the following:
