Order Jeopardy Editor Policy Tab Duration Value Subtab
Use the Order Jeopardy editor Policy tab, Duration Value subtab to set the details of the duration timer. This subtab is available if the Specify a Duration Value option is selected in the Order Jeopardy editor Policy tab, Timer Duration area.
| Field | Use |
Duration Amount |
Enter the number of duration units to wait before raising a jeopardy on the order. |
Duration Unit |
Select the appropriate units for the duration value from the list. |
Related Topics
