Creating Jeopardy Notifications in the Order Jeopardy Editor
Create jeopardy notifications using the Order Jeopardy editor when you want the most flexibility in defining the jeopardy conditions to alert users or systems of orders that may be at risk.
To create a jeopardy notification:
From the Studio menu, select New, select Order and Service Management, select Order Management, then select Order Jeopardy.
The Order Jeopardy wizard is displayed.
In the Project field, select the project in which to save the order jeopardy.
In the Name field, enter a name for the order jeopardy.
The name must be unique among order jeopardy entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the order jeopardy.
Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the order jeopardy.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new order jeopardy to the Studio Projects view and opens the new entity in the Order Jeopardy editor.
In the Details tab, configure the required fields, which are Target Order and Roles, as well as any optional fields appropriate for your situation.
For more information about the fields in this tab, see "Order Jeopardy Editor Details Tab."
In the Policy tab, configure the conditions under which the jeopardy should be raised.
For more information about the fields in this tab, see "Order Jeopardy Editor Policy Tab."
(Optional) In the Automation tab, configure the information about any automation that should be triggered when the jeopardy notification is raised.
For more information about the fields in this tab, see "Order Jeopardy Editor Automation Tab."
Related Topics
