Properties View Filter Expression Tab
Use the Order editor Properties view Filter Expression tab to define rule expressions. To access the Filter Expression tab, select a conditional expression on the Order editor Permissions Filter tab and click Properties.
The fields on the Filter Expression tab are identical to those on the Order editor Permissions Filters tab. When you select values on this tab, they appear in the Order editor Permissions Filter tab. See "Order Editor Permissions Filters Tab" for more information.
