Adding a New Data Structure Definition to a Task
You can create and add a new data structure definition to a task. See "About OSM Data in Model Projects" for more information about data structure definitions.
To add a new data structure definition to a task:
Right-click inside the Task editor Task Data tab.
See "Task Editor Task Data Tab" for more information about the fields on this tab. When modeling data for activation tasks, navigate to the Task Request Data tab and right-click in the Task Data area.
Select Select Data Structure Definition.
A dialog box is displayed, enabling you to select data structure definitions.
You can alternatively select Open Data Element view and then drag data elements from the Data Dictionary onto the Task Data area.
Select the data that you want to add to the task.
Click OK.
Design Studio adds the data structure definitions to the Task editor Task Data area.
Click Save.
