Studio Environment Editor Connection Tab
Use the Studio Environment editor Connection tab to define the connection parameter necessary to connect to the run-time environment.
| Field | Use |
Address |
Enter the WebLogic IP address (or the fully qualified domain name if DNS is enabled) and port necessary to connect to the OSM run-time environment. During initial OSM installation, the OSM installer program connects to a running Oracle WebLogic server to automatically deploy the cartridge_management_ws.ear file, which contains the Cartridge Management Web Service that enables you to connect to OSM from Design Studio. In the Studio Environment editor Address field, Design Studio displays a default destination URL for this Oracle WebLogic server. However, you must edit the IP address/server name and port number to match your own server address configuration:
where
Note: If you are deploying to a
clustered environment, specify the proxy server for
See OSM Installation Guide for more information about installing OSM and connecting to Oracle WebLogic servers. |
